Labels for a Philco 37-620 and Cap replacement
Anyone have any further input on the replacement of the two buried caps in the very front of the center RF section of the chassis? Am I safe to assume one would remove or lift up the top section of it (with the tube sockets)? I can't see that removing the rubber shock mounts to allow lifting of the whole assembly would do much. Guess no one out there has any graphics for the tube layout either. Thanks for any further help.
Jerry
Edit, label graphics have been received.
Re: Labels for a Philco 37-620 - by 7estatdef - 04-29-2011, 05:00 PM
Re: Labels for a Philco 37-620 - by 7estatdef - 04-29-2011, 09:03 PM
Re: Labels for a Philco 37-620 - by Ron Ramirez - 04-29-2011, 09:37 PM
Re: Labels for a Philco 37-620 - by jerryhawthorne - 05-02-2011, 11:46 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6360 online users. [Complete List]
» 1 Member(s) | 6359 Guest(s)
