help me id these radios
On the top cabinet photo - Not only has the stretcher base been cut off, but parts of each leg have also been cut off. Yes, the chassis is obviously a 112 with that NORMAL - MAX switch. Only the 111 and 112 had that. And since you say it uses 47 outputs, then it must be a late 112 chassis.
Both are 1929 models. Count the number of tubes in the chassis which is inside the radio in the bottom photo to see what you have.
6 tubes - model 65
7 tubes - model 76
8 tubes - model 87
9 tubes - model 95
help me id these radios - by mg34.42 - 01-03-2022, 02:09 AM
RE: help me id these radios - by Brad Winder - 01-03-2022, 02:54 AM
RE: help me id these radios - by Ron Ramirez - 01-03-2022, 09:23 AM
RE: help me id these radios - by mg34.42 - 01-22-2022, 07:02 PM
RE: help me id these radios - by Ron Ramirez - 01-22-2022, 07:04 PM
RE: help me id these radios - by mg34.42 - 01-22-2022, 07:23 PM
RE: help me id these radios - by Ron Ramirez - 01-22-2022, 08:23 PM
RE: help me id these radios - by mg34.42 - 01-22-2022, 08:38 PM
Eico 232 VTVM Schematic
