  • 1 Vote(s) - 5 Average
Signal Generator
Mondial
It does. But the knob will wait until you pick a function. You can see the amplitude (this is attenuation) and "MOD" (which should be a modulation).
Signal Generator - by VintageRocks - 01-02-2022, 09:10 PM
RE: Signal Generator - by morzh - 01-02-2022, 10:00 PM
RE: Signal Generator - by radiorich - 01-02-2022, 11:34 PM
RE: Signal Generator - by VintageRocks - 01-03-2022, 10:55 AM
RE: Signal Generator - by morzh - 01-03-2022, 01:08 PM
RE: Signal Generator - by Mondial - 01-03-2022, 02:24 PM
RE: Signal Generator - by morzh - 01-03-2022, 09:47 PM
RE: Signal Generator - by Mondial - 01-03-2022, 10:14 PM
RE: Signal Generator - by morzh - 01-03-2022, 10:54 PM
RE: Signal Generator - by rfeenstra - 01-04-2022, 12:56 AM
RE: Signal Generator - by VintageRocks - 01-04-2022, 09:12 AM
RE: Signal Generator - by mikethedruid - 01-04-2022, 10:22 AM
RE: Signal Generator - by John Bartley - 01-04-2022, 10:46 AM
462ron - by 462ron - 01-04-2022, 12:01 PM
