Adding FM to a Philco 118
The FM module has been mounted to the front wall of the chassis. All connections have been made, I used small shielded cable for the audio.
[Image: https://live.staticflickr.com/65535/5179...b60d_c.jpg]Adding FM to a Philco 118 by Steve Davis, on Flickr
The module requires 6.3 to 16 volts AC or DC with one side grounded to the chassis. The Philco 118 uses 6.3 volt tubes but, the 6.3 volt winding has a grounded center tap. This is a problem. One half of the winding could be used with a voltage doubler circuit. I looked all through my "someday kit" and could not find a suitable capacitor to make the doubler. But, I did find about a half a dozen of these nice little 12 volt, 150ma transformers, so I decided to go with one of them.
[Image: https://live.staticflickr.com/65535/5179...a7f8_c.jpg]Adding FM to a Philco 118 by Steve Davis, on Flickr
The open circuit voltage of the transformer is 16 volts, right at the high limit of the module. With a 150ma transformer and only a 24ma draw from the module, my fear is, the voltage might not come down much from the 16 volts. I decided to remove a few turns from the secondary winding. I disassembled the transformer and unwound 80 turns then reassembled the transformer. The OC came down to 10 volts, good enough.
[Image: https://live.staticflickr.com/65535/5179...77f8_c.jpg]Adding FM to a Philco 118 by Steve Davis, on Flickr
M R Radios   C M Tubes
Adding FM to a Philco 118 - by Steve Davis - 12-30-2021, 12:15 AM
RE: Adding FM to a Philco 118 - by morzh - 12-30-2021, 12:44 AM
RE: Adding FM to a Philco 118 - by Steve Davis - 12-30-2021, 01:04 AM
RE: Adding FM to a Philco 118 - by Arran - 12-30-2021, 04:16 AM
RE: Adding FM to a Philco 118 - by GarySP - 12-30-2021, 08:35 AM
RE: Adding FM to a Philco 118 - by willydcamaro - 12-30-2021, 02:26 PM
RE: Adding FM to a Philco 118 - by Radioroslyn - 12-30-2021, 03:16 PM
RE: Adding FM to a Philco 118 - by Ron Ramirez - 12-30-2021, 08:03 PM
RE: Adding FM to a Philco 118 - by Steve Davis - 12-30-2021, 10:55 PM
RE: Adding FM to a Philco 118 - by radiorich - 12-30-2021, 11:55 PM
RE: Adding FM to a Philco 118 - by Steve Davis - 12-31-2021, 08:35 PM
RE: Adding FM to a Philco 118 - by Steve Davis - 12-31-2021, 09:52 PM
RE: Adding FM to a Philco 118 - by radiorich - 01-01-2022, 12:19 AM
RE: Adding FM to a Philco 118 - by Steve Davis - 01-03-2022, 09:56 PM
RE: Adding FM to a Philco 118 - by Steve Davis - 01-04-2022, 12:46 PM
RE: Adding FM to a Philco 118 - by radiorich - 01-04-2022, 02:54 PM
RE: Adding FM to a Philco 118 - by exray - 01-06-2022, 05:31 PM
RE: Adding FM to a Philco 118 - by Steve Davis - 01-06-2022, 08:20 PM
RE: Adding FM to a Philco 118 - by exray - 01-06-2022, 09:08 PM
RE: Adding FM to a Philco 118 - by Paul Philco322 - 01-06-2022, 10:06 PM
RE: Adding FM to a Philco 118 - by Steve Davis - 01-07-2022, 12:08 AM
RE: Adding FM to a Philco 118 - by radiorich - 01-07-2022, 01:11 AM
RE: Adding FM to a Philco 118 - by exray - 01-07-2022, 08:48 AM
RE: Adding FM to a Philco 118 - by radiorich - 01-07-2022, 09:10 AM
RE: Adding FM to a Philco 118 - by exray - 01-07-2022, 10:10 AM
RE: Adding FM to a Philco 118 - by Steve Davis - 01-07-2022, 10:23 AM
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 5192 online users. [Complete List]
» 3 Member(s) | 5189 Guest(s)
