38-690 Code 125
#55
Yes, you probably were not feeding in enough signal to activate the AVC. You will need a somewhat strong signal as the 690 has a delayed avc circuit.
The 6J5 AVC rectifier cathode is biased a few volts positive, and the grid (used as the plate) is biased negative, so the IF signal amplitude must be high enough to overcome the initial bias before AVC voltage is generated.
The initial 2.4V negative bias applied to the grid of the 6J5 is what you are seeing on the IF 6K7 grids. It should increase with a strong enough signal.
38-690 Code 125 - by RGK20m3 - 11-24-2021, 08:26 PM
RE: 38-690 Code 125 - by klondike98 - 11-24-2021, 09:01 PM
RE: 38-690 Code 125 - by RGK20m3 - 11-26-2021, 05:41 PM
RE: 38-690 Code 125 - by klondike98 - 11-26-2021, 06:21 PM
RE: 38-690 Code 125 - by RGK20m3 - 11-26-2021, 10:29 PM
RE: 38-690 Code 125 - by RGK20m3 - 12-02-2021, 07:35 PM
RE: 38-690 Code 125 - by morzh - 12-02-2021, 08:09 PM
RE: 38-690 Code 125 - by Ron Ramirez - 12-02-2021, 08:58 PM
RE: 38-690 Code 125 - by morzh - 12-02-2021, 09:02 PM
RE: 38-690 Code 125 - by radiorich - 12-02-2021, 10:01 PM
RE: 38-690 Code 125 - by Ron Ramirez - 12-02-2021, 11:41 PM
RGK20m3 - by RGK20m3 - 12-05-2021, 06:03 PM
RE: 38-690 Code 125 - by David - 12-05-2021, 07:19 PM
RE: 38-690 Code 125 - by klondike98 - 12-09-2021, 08:08 PM
RGK20m3 - by RGK20m3 - 12-10-2021, 02:54 PM
RE: 38-690 Code 125 - by Mondial - 12-10-2021, 06:42 PM
RE: 38-690 Code 125 - by RGK20m3 - 12-10-2021, 07:15 PM
RE: 38-690 Code 125 - by morzh - 12-10-2021, 07:27 PM
RE: 38-690 Code 125 - by Mondial - 12-10-2021, 07:40 PM
RE: 38-690 Code 125 - by mikethedruid - 12-10-2021, 08:01 PM
RGK20m3 - by RGK20m3 - 12-10-2021, 10:09 PM
RGK20m3 - by RGK20m3 - 12-11-2021, 12:14 PM
RE: 38-690 Code 125 - by Mondial - 12-11-2021, 01:58 PM
RGK20m3 - by RGK20m3 - 12-11-2021, 05:41 PM
RE: 38-690 Code 125 - by Mondial - 12-11-2021, 06:48 PM
RE: 38-690 Code 125 - by tbone - 12-12-2021, 02:27 PM
RGK20m3 - by RGK20m3 - 12-13-2021, 08:24 PM
RE: 38-690 Code 125 - by Mondial - 12-14-2021, 10:22 AM
RE: 38-690 Code 125 - by morzh - 12-14-2021, 12:40 PM
RE: 38-690 Code 125 - by Ron Ramirez - 12-14-2021, 01:40 PM
RE: 38-690 Code 125 - by RGK20m3 - 12-14-2021, 03:25 PM
RE: 38-690 Code 125 - by morzh - 12-14-2021, 03:35 PM
RE: 38-690 Code 125 - by Mondial - 12-14-2021, 04:06 PM
RE: 38-690 Code 125 - by Ron Ramirez - 12-14-2021, 04:42 PM
RGK20m3 - by RGK20m3 - 12-14-2021, 10:32 PM
RE: 38-690 Code 125 - by Ron Ramirez - 12-14-2021, 10:58 PM
RGK20m3 - by RGK20m3 - 12-15-2021, 09:01 AM
RGK20m3 - by RGK20m3 - 12-15-2021, 11:55 AM
RE: 38-690 Code 125 - by Mondial - 12-15-2021, 03:02 PM
RGK20m3 - by RGK20m3 - 12-15-2021, 05:14 PM
RE: 38-690 Code 125 - by RGK20m3 - 01-02-2022, 06:05 PM
RE: 38-690 Code 125 - by Greg - 01-02-2022, 06:42 PM
RE: 38-690 Code 125 - by Mondial - 01-02-2022, 07:59 PM
RGK20m3 - by RGK20m3 - 01-03-2022, 12:36 PM
RE: 38-690 Code 125 - by Mondial - 01-03-2022, 01:43 PM
RGK20m3 - by RGK20m3 - 01-04-2022, 09:12 AM
RE: 38-690 Code 125 - by Mondial - 01-04-2022, 12:21 PM
RE: 38-690 Code 125 - by RGK20m3 - 01-04-2022, 07:01 PM
RGK20m3 - by RGK20m3 - 01-05-2022, 12:36 PM
RE: 38-690 Code 125 - by Mondial - 01-05-2022, 01:56 PM
RGK20m3 - by RGK20m3 - 01-05-2022, 02:57 PM
RE: 38-690 Code 125 - by Mondial - 01-05-2022, 05:59 PM
RGK20m3 - by RGK20m3 - 01-06-2022, 07:39 PM
RE: 38-690 Code 125 - by Mondial - 01-07-2022, 11:44 AM
RE: 38-690 Code 125 - by RGK20m3 - 01-07-2022, 01:03 PM
RGK20m3 - by RGK20m3 - 01-07-2022, 01:32 PM
RE: 38-690 Code 125 - by Mondial - 01-07-2022, 01:49 PM
RGK20m3 - by RGK20m3 - 01-07-2022, 02:31 PM
RGK20m3 - by RGK20m3 - 01-29-2022, 01:25 PM
RE: 38-690 Code 125 - by Brad Winder - 02-02-2022, 08:30 PM
RGK20m3 - by RGK20m3 - 02-04-2022, 07:41 PM
RE: 38-690 Code 125 - by Brad Winder - 02-06-2022, 02:53 PM
RE: 38-690 Code 125 - by RGK20m3 - 02-07-2022, 11:26 AM
38-690 RF Alignment - by RGK20m3 - 12-09-2021, 02:54 PM
RE: 38-690 RF Alignment - by morzh - 12-09-2021, 04:16 PM
RE: 38-690 RF Alignment - by RGK20m3 - 12-09-2021, 04:40 PM
Users browsing this thread: 14 Guest(s)
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 4895 online users. [Complete List]
» 2 Member(s) | 4893 Guest(s)
