38-7 Chairside Concentric Tuning Dial
I decided to do the glass replacement myself.  I removed the old glass and found what looked like old black rubber and don't know if it was originally a 'gasket' or if it was some type of adhesive.  I soaked the adhesive with alcohol and removed what I could see.
I noticed the friction ring was held in place by indentations from the brass piece.  See picture.  I used a 1/16in drill bit and drilled out the indentations, but the ring still wouldn't move.  The drilled holes will not show once assembled.
I then soaked the space between the ring and the outer brass cover with alcohol and finally sprayed it with penetrating oil (PB Blaster) every hour for a few hours and let it sit overnight.  Next morning the ring slid off with a little pressure.
I haven't decided what I'm going to use to replace the old rubber.  RTV or rubber cement.  The ring fits tight, just need something to keep the glass solid.
I want to thank everyone for the help.  Gave me the courage to move forward on my own.
38-7 Chairside Concentric Tuning Dial - by LJB - 01-18-2022, 05:53 PM
RE: 38-7 Chairside Concentric Tuning Dial - by LJB - 01-23-2022, 10:59 PM
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 3249 online users. [Complete List]
» 3 Member(s) | 3246 Guest(s)
