  • 1 Vote(s) - 3 Average
Heathkit SG-6 signal generator
If you follow the hv around thru the 6C4 osc tube the plate and cathode should be at about the same potential. Unless the variable cap is shorted (rubbing plates). I think it's about 80vdc. RF wise the plate is at ground thru that .01 cap.
I'm assuming you've replaced the caps, out of tolerance resistors, and the power supply is making 140vdc or so at the cathode of the rectifier.  Q Tips and denatured alcohol does wonders for the switch contacts.
Heathkit SG-6 signal generator - by Rob Quay - 01-27-2022, 12:00 PM
RE: Heathkit SG-6 signal generator - by vinzer - 01-27-2022, 02:20 PM
RE: Heathkit SG-6 signal generator - by Radioroslyn - 01-27-2022, 02:43 PM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-27-2022, 03:13 PM
RE: Heathkit SG-6 signal generator - by morzh - 01-27-2022, 08:22 PM
RE: Heathkit SG-6 signal generator - by GarySP - 01-28-2022, 11:11 AM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-28-2022, 11:40 PM
RE: Heathkit SG-6 signal generator - by morzh - 01-29-2022, 06:36 PM
462ron - by 462ron - 01-30-2022, 01:11 PM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-30-2022, 08:42 PM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-31-2022, 01:44 PM
Eico 232 VTVM Schematic
There are currently 9408 online users. [Complete List]
» 2 Member(s) | 9406 Guest(s)
