Pilot 3 inch TV.
I've seen images with the magnifier on the set and it looks neat, but I guess they hooked right onto the grill bars! Icon_eek From what I have read, the magnifier usually either broke or bent the bars over time. My Pilot has virtually perfect grills on it, so it probably never had the magnifier.
Pilot 3 inch TV. - by Jayce - 04-30-2011, 08:02 PM
Re: Pilot 3 inch TV. - by 7estatdef - 05-01-2011, 08:03 AM
Re: Pilot 3 inch TV. - by exray - 05-01-2011, 06:16 PM
Re: Pilot 3 inch TV. - by TA Forbes - 05-01-2011, 07:08 PM
Re: Pilot 3 inch TV. - by 7estatdef - 05-01-2011, 08:17 PM
Re: Pilot 3 inch TV. - by Jayce - 05-01-2011, 11:05 PM
Re: Pilot 3 inch TV. - by TA Forbes - 05-02-2011, 08:56 AM
Re: Pilot 3 inch TV. - by Jayce - 05-02-2011, 07:39 PM
Re: Pilot 3 inch TV. - by codefox1 - 05-02-2011, 08:23 PM
Re: Pilot 3 inch TV. - by Jayce - 05-03-2011, 12:46 PM
Re: Pilot 3 inch TV. - by exray - 05-03-2011, 05:28 PM
Re: Pilot 3 inch TV. - by Jayce - 05-06-2011, 01:05 PM
Re: Pilot 3 inch TV. - by Arran - 05-09-2011, 01:36 AM
Eico 232 VTVM Schematic
There are currently 9014 online users. [Complete List]
» 1 Member(s) | 9013 Guest(s)
