  • 1 Vote(s) - 3 Average
Heathkit SG-6 signal generator
Hi Guys- Checked out voltages and cleaned tube pins, switches etc. The signal generator works but accuracy is an issue. Time to consider an upgrade. I got it awhile back when taking a radio repair class at the museum in Bowie Md.
It was good as a learning tool so I consider the $12 I spent for it as an investment. Thanks for the input! - Rob Q.
Heathkit SG-6 signal generator - by Rob Quay - 01-27-2022, 12:00 PM
RE: Heathkit SG-6 signal generator - by vinzer - 01-27-2022, 02:20 PM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-27-2022, 03:13 PM
RE: Heathkit SG-6 signal generator - by morzh - 01-27-2022, 08:22 PM
RE: Heathkit SG-6 signal generator - by GarySP - 01-28-2022, 11:11 AM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-28-2022, 11:40 PM
RE: Heathkit SG-6 signal generator - by morzh - 01-29-2022, 06:36 PM
462ron - by 462ron - 01-30-2022, 01:11 PM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-30-2022, 08:42 PM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-31-2022, 01:44 PM
