  • 1 Vote(s) - 3 Average
Heathkit SG-6 signal generator
Adding BK counter (same as Ron did) helped but it was a half-measure. I mean, I paid $20 for a working unit so either Leader SG-11 or Heath SG-8 paired with it was an inexpensive setup, so I did not lose much by retiring it to the shelf.
Half-measure it was because the SG, in addition to the absolurte inaccuracy (scale vs the actual frequency), and the waveshape that was all but sinewave (and I was playing with the cathode follower that made it such - nothing helped), the frequency also drifted. Slowly, but by time you adjusted the trimmer or what have you it could go away by 100Hz, and if you did not re-adjust it every time netween the adjustments, at the end of it the frequency could easily drift by a few hundred HZ to 1kHz. No amount of warm-up helped.
So, yes, get thee a nice synthesizer, old or today's, make a protective cable with two back-to-back diodes, and this will make you a very happy alingnment person.
Heathkit SG-6 signal generator - by Rob Quay - 01-27-2022, 12:00 PM
RE: Heathkit SG-6 signal generator - by vinzer - 01-27-2022, 02:20 PM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-27-2022, 03:13 PM
RE: Heathkit SG-6 signal generator - by morzh - 01-27-2022, 08:22 PM
RE: Heathkit SG-6 signal generator - by GarySP - 01-28-2022, 11:11 AM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-28-2022, 11:40 PM
RE: Heathkit SG-6 signal generator - by morzh - 01-29-2022, 06:36 PM
462ron - by 462ron - 01-30-2022, 01:11 PM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-30-2022, 08:42 PM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-31-2022, 01:44 PM
