  • 1 Vote(s) - 3 Average
Heathkit SG-6 signal generator
Rob, check out post#14 in this link https://philcoradio.com/phorum/showthread.php?tid=23161. It shows what I did to my SG-8. Makes my setup fairly easy to use and easy to make the mods!
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Heathkit SG-6 signal generator - by Rob Quay - 01-27-2022, 12:00 PM
RE: Heathkit SG-6 signal generator - by vinzer - 01-27-2022, 02:20 PM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-27-2022, 03:13 PM
RE: Heathkit SG-6 signal generator - by morzh - 01-27-2022, 08:22 PM
RE: Heathkit SG-6 signal generator - by GarySP - 01-28-2022, 11:11 AM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-28-2022, 11:40 PM
RE: Heathkit SG-6 signal generator - by morzh - 01-29-2022, 06:36 PM
462ron - by 462ron - 01-30-2022, 01:11 PM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-30-2022, 08:42 PM
RE: Heathkit SG-6 signal generator - by Rob Quay - 01-31-2022, 01:44 PM
Eico 232 VTVM Schematic
There are currently 8980 online users. [Complete List]
» 1 Member(s) | 8979 Guest(s)
