41-285 troubleshooting help
So if you apply a 455kc signal at pin 6 of the 1st IF amp you get no response from the speaker? If so check the voltages at pins 2,3,and 7 from chassis ground and report back.
41-285 troubleshooting help - by jstaf40 - 05-03-2011, 08:21 PM
Re: 41-285 troubleshooting help - by 7estatdef - 05-03-2011, 09:52 PM
Re: 41-285 troubleshooting help - by jstaf40 - 05-04-2011, 09:25 PM
Re: 41-285 troubleshooting help - by 7estatdef - 05-04-2011, 09:43 PM
Re: 41-285 troubleshooting help - by jstaf40 - 05-06-2011, 01:11 PM
Re: 41-285 troubleshooting help - by 7estatdef - 05-06-2011, 05:49 PM
Re: 41-285 troubleshooting help - by jstaf40 - 05-07-2011, 04:42 PM
Re: 41-285 troubleshooting help - by 7estatdef - 05-07-2011, 09:21 PM
Re: 41-285 troubleshooting help - by jstaf40 - 05-09-2011, 05:26 PM
Re: 41-285 troubleshooting help - by 7estatdef - 05-09-2011, 06:19 PM
The speaker table error?
Philco 70 antenna lead
