Philco 38-12
Well the little tuning job turned into a few hours with no luck. Since I installed the new oscillator, the IF cans and padders where all over the place. On top of that, it SOUNDS LIKE it's running in a variac at 50% and misaligned. The rich sound is gone and it sounds nasal. The stations are not lining up. I put my signal generator to the grid of the 6A7 tube, tried alignment there and it still sounds bad. Any ideas? Thanks!!!
Philco 38-12 - by radiola - 05-02-2011, 08:07 PM
Re: Philco 38-12 - by 7estatdef - 05-02-2011, 09:16 PM
Re: Philco 38-12 - by radiola - 05-02-2011, 10:19 PM
Re: Philco 38-12 - by 7estatdef - 05-02-2011, 11:20 PM
Re: Philco 38-12 - by radiola - 05-02-2011, 11:32 PM
Re: Philco 38-12 - by radiola - 05-03-2011, 01:33 AM
Re: Philco 38-12 - by 7estatdef - 05-03-2011, 06:24 AM
Re: Philco 38-12 - by radiola - 05-03-2011, 09:57 AM
Re: Philco 38-12 - by 7estatdef - 05-03-2011, 06:32 PM
Re: Philco 38-12 - by radiola - 05-03-2011, 08:58 PM
Re: Philco 38-12 - by 7estatdef - 05-03-2011, 09:48 PM
Re: Philco 38-12 - by radiola - 05-06-2011, 02:42 AM
Re: Philco 38-12 - by 7estatdef - 05-06-2011, 09:53 AM
Re: Philco 38-12 - by radiola - 05-06-2011, 06:02 PM
Re: Philco 38-12 - by 7estatdef - 05-06-2011, 07:43 PM
Re: Philco 38-12 - by radiola - 05-06-2011, 10:45 PM
Re: Philco 38-12 - by radiola - 05-07-2011, 04:04 PM
Re: Philco 38-12 - by 7estatdef - 05-07-2011, 04:21 PM
Re: Philco 38-12 - by radiola - 05-09-2011, 09:46 PM
Re: Philco 38-12 - by radiola - 05-15-2011, 05:27 PM
Re: Philco 38-12 - by radiola - 05-18-2011, 07:21 PM
Re: Philco 38-12 - by 7estatdef - 05-18-2011, 08:04 PM
Re: Philco 38-12 - by radiola - 05-18-2011, 10:11 PM
Re: Philco 38-12 - by 7estatdef - 05-18-2011, 10:54 PM
Re: Philco 38-12 - by radiola - 05-19-2011, 10:45 PM
Re: Philco 38-12 - by 7estatdef - 05-20-2011, 08:56 AM
Re: Philco 38-12 - by radiola - 05-20-2011, 05:26 PM
Re: Philco 38-12 - by 7estatdef - 05-20-2011, 08:04 PM
Re: Philco 38-12 - by radiola - 05-20-2011, 09:20 PM
Re: Philco 38-12 - by 7estatdef - 05-20-2011, 10:10 PM
Re: Philco 38-12 - by radiola - 05-21-2011, 11:23 PM
The speaker table error?
Philco 70 antenna lead
