Philco 60
Let me see if I can untangle your mystery.
The tube socket in the middle of the pic, the 7pin one is the 6A7 not the 78. The 78 uses a six pin socket. The 47,000 ohm is pretending to be #19 which is fine as long as it's with in spec. The loose end goes to chassis gnd.
You could have wired at pin 3 of the 6A7, #20A, ungrounded side of #19, and the left side of #22.
On the 78 (IF amp) the cathode and suppressor grid probably are connected together. If you measure the resistance from pin 5 the the chassis you should about 200 ohms. The later models have the suppressor grid grounded separate from the cathode. The 78 cathode is connected to the 6A7 cathode so they could use just one resistor vs two.
Philco 60 - by Ralph - 12-29-2021, 11:34 AM
RE: Philco 60 - by Radioroslyn - 12-29-2021, 12:56 PM
RE: Philco 60 - by Ralph - 12-29-2021, 07:29 PM
RE: Philco 60 - by Radioroslyn - 12-29-2021, 08:43 PM
RE: Philco 60 - by Ralph - 01-31-2022, 08:13 AM
RE: Philco 60 - by Radioroslyn - 01-31-2022, 09:22 AM
RE: Philco 60 - by Ralph - 01-31-2022, 04:19 PM
RE: Philco 60 - by Radioroslyn - 01-31-2022, 04:58 PM
RE: Philco 60 - by sk373a@gmail.com - 02-01-2022, 10:06 AM
RE: Philco 60 - by Lewiss - 02-02-2022, 02:21 PM
RE: Philco 60 - by Ralph - 02-03-2022, 11:10 AM
RE: Philco 60 - by Lewiss - 02-03-2022, 06:22 PM
RE: Philco 60 - by Ralph - 02-04-2022, 04:40 PM
RE: Philco 60 - by Radioroslyn - 02-04-2022, 05:27 PM
RE: Philco 60 - by Ralph - 02-04-2022, 05:59 PM
RE: Philco 60 - by Ralph - 02-18-2022, 07:40 PM
RE: Philco 60 - by Lewiss - 02-21-2022, 02:37 PM
RE: Philco 60 - by mikethedruid - 02-21-2022, 07:22 PM
RE: Philco 60 - by Ralph - 02-24-2022, 05:12 PM
RE: Philco 60 - by mikethedruid - 02-24-2022, 10:25 PM
RE: Philco 60 - by Mondial - 02-25-2022, 04:07 PM
RE: Philco 60 - by Ralph - 02-25-2022, 06:48 PM
RE: Philco 60 - by Ralph - 03-12-2022, 01:07 PM
RE: Philco 60 - by klondike98 - 03-12-2022, 01:16 PM
RE: Philco 60 - by Ralph - 03-12-2022, 01:26 PM
RE: Philco 60 - by klondike98 - 03-12-2022, 05:47 PM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
Ron yes, that was found. The problem is trying to find GE-10 for AR107/108. I could not find even mentioning of it. ...morzh — 09:06 AM
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM
Mike; Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
So, I sat down, and first tried 40 AWG wire. It broke quickly. I retook diameter: this one was 0.05mm whereas the one I ...morzh — 08:24 PM
There are currently 3410 online users. [Complete List]
» 1 Member(s) | 3409 Guest(s)
