Push Pull tube amp kit from China
Tim, is that a double sided board?
I think I would be tempted to replace the electrolytics they furnish with the kit with Nichicon and/or Panasonic, and the film caps with WIMA, for greater reliability. But that's just my opinion. I hope the kit turns out well!
Push Pull tube amp kit from China - by TV MAN - 02-03-2022, 10:03 PM
RE: Push Pull tube amp kit from China - by TV MAN - 02-03-2022, 10:18 PM
RE: Push Pull tube amp kit from China - by TV MAN - 02-05-2022, 12:13 PM
RE: Push Pull tube amp kit from China - by Ron Ramirez - 02-05-2022, 12:39 PM
RE: Push Pull tube amp kit from China - by morzh - 02-05-2022, 05:27 PM
RE: Push Pull tube amp kit from China - by TV MAN - 02-07-2022, 03:20 PM
RE: Push Pull tube amp kit from China - by morzh - 02-13-2022, 08:23 PM
RE: Push Pull tube amp kit from China - by TV MAN - 03-02-2022, 01:04 PM
RE: Push Pull tube amp kit from China - by morzh - 03-04-2022, 08:34 PM
RE: Push Pull tube amp kit from China - by TV MAN - 03-09-2022, 10:21 AM
RE: Push Pull tube amp kit from China - by TV MAN - 03-10-2022, 12:40 PM
RE: Push Pull tube amp kit from China - by TV MAN - 03-11-2022, 02:18 PM
RE: Push Pull tube amp kit from China - by TV MAN - 03-11-2022, 03:24 PM
RE: Push Pull tube amp kit from China - by TV MAN - 03-13-2022, 11:31 PM
RE: Push Pull tube amp kit from China - by TV MAN - 03-14-2022, 01:53 PM
RE: Push Pull tube amp kit from China - by TV MAN - 03-22-2022, 08:55 AM
RE: Push Pull tube amp kit from China - by TV MAN - 03-22-2022, 11:25 PM
RE: Push Pull tube amp kit from China - by TV MAN - 03-23-2022, 11:35 PM
RE: Push Pull tube amp kit from China - by TV MAN - 01-08-2025, 04:29 PM
RE: Push Pull tube amp kit from China - by morzh - 01-08-2025, 06:36 PM
RE: Push Pull tube amp kit from China - by TV MAN - 01-08-2025, 07:56 PM
RE: Push Pull tube amp kit from China - by TV MAN - 01-09-2025, 03:27 PM
