Motorola 605
I agree with Jerry. On most all the radios back then I've seen you would set the stations as Jerry stated. The button should pull out about half an inch if I recall correctly. Good luck. Take care and BE HEALTHY! Gary
Motorola 605 - by Antipodal - 02-07-2022, 07:13 PM
RE: Motorola 605 - by jerryhawthorne - 02-07-2022, 08:57 PM
RE: Motorola 605 - by GarySP - 02-07-2022, 09:10 PM
RE: Motorola 605 - by Antipodal - 02-07-2022, 10:54 PM
RE: Motorola 605 - by Mondial - 02-08-2022, 01:02 AM
RE: Motorola 605 - by Antipodal - 02-09-2022, 03:41 AM
