4x6 Speaker Question for 42-345
Hi Cdoyl,
Look at the old speaker carefully. There are 2 "coils" in that field coil. The one with a high resistance of 1600 -1700 is the one connected between the + terminal of the 2 Caps, 57 and 40A. The other coil is the "hum bucking" coil which you can either leave out of the circuit or put it in. However, if you use it, polarity is important. one direction will "buck" the hum; reverse the connections, and the hum will be boosted. Use the best of the 3 options. The Voice Coil does have 2 connections. one may be directly to the frame of the speaker. Car radio manufacturers did this a lot in the 50s, and Philco was a major car radio manufacturer.
The Schematic that Ron Ramirez shares in his link shows the connection between the hum bucking coil and the transformer to be grounded to the chassis.
If you can post another pic of the speaker with the voice coil and hum bucking coil connections more visible, this will be helpful, as well as a pic of the wiring extending from the Output Transformer secondary.
John, MrFixr55
4x6 Speaker Question for 42-345 - by cdoyal - 02-07-2022, 07:39 PM
RE: 4x6 Speaker Question for 42-345 - by MrFixr55 - 02-07-2022, 09:36 PM
RE: 4x6 Speaker Question for 42-345 - by MrFixr55 - 02-07-2022, 10:08 PM
RE: 4x6 Speaker Question for 42-345 - by cdoyal - 02-08-2022, 10:19 AM
RE: 4x6 Speaker Question for 42-345 - by MrFixr55 - 02-09-2022, 07:09 AM
RE: 4x6 Speaker Question for 42-345 - by cdoyal - 02-09-2022, 11:58 AM
RE: 4x6 Speaker Question for 42-345 - by MrFixr55 - 02-09-2022, 02:29 PM
RE: 4x6 Speaker Question for 42-345 - by cdoyal - 02-12-2022, 09:51 PM
RE: 4x6 Speaker Question for 42-345 - by MrFixr55 - 02-13-2022, 03:28 PM
RE: 4x6 Speaker Question for 42-345 - by cdoyal - 02-20-2022, 01:58 PM
RE: 4x6 Speaker Question for 42-345 - by MrFixr55 - 02-20-2022, 10:04 PM
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
