advice needed: restoring 47-1230 - FM & AM now works!!!! :D (uncertain about SW)
You should post the photo so others can see it. Icon_smile
Philco schematics sometimes have errors in them. Some mistakes were caught and corrected; others weren't. It is when the mistakes weren't caught and corrected, that things get interesting for us, decades later, as we try to get these sets going again.
Re: advice needed: restoring 47-1230 - got AM back!!!! - by Ron Ramirez - 05-07-2011, 08:19 PM
Philco 91 Tuning Condenser
There are currently 4351 online users. [Complete List]
» 1 Member(s) | 4350 Guest(s)
