Philco 60 hot resistor
Hi I have a philco model 60 that has been recapped. Sometimes it wont play and the number 14 32000 ohm resistor on the wiring diagram gets very hot and no sound from the speaker. So I replaced the 1/2 watt  32000 ohm resistor with a 1 watt 32000 ohm resistor. The resistor still gets very hot and still no sound from the speaker. Sometimes the radio plays fine and the resistor does not get hot. while the radio was not playing and the resistor getting too hot I was looking for a bad solder joint and accidently pulled one of the wires that connects between the 32000 ohm resistor and the oscillator coil off the oscillator coil the radio started playing. So I replaced that wire and made sure it was soldered good on both ends. I turned the radio on and it did not play and the resistor got very hot. I then cut the new wire between the 32000 ohm resistor and the oscillator coil and the radio played and the resistor did not get hot. While the radio was playing I connected the wire back togather and the radio kept playing and got a little louder. I turned the radio off and on It played fine. About the third time I turned it off and back on the radio did not play and the resistor got very hot. I disconnected the same wire and the radio played. While it was playing I connected the wire together and the radio got a little louder and kept playing and the resistor did not get hot. Sometimes the radio will play fine when I turn it on and the resistor does not get hot. Other times when I turn it on it will not play and the resistor gets very hot until I disconnect the wire and it plays and gets a little louder and the resistor cools off. Sometimes the radio plays fine with the wire connected and plays for hours. Sometimes the radio will play fine with the wire connected for 20-30 minutes and go silent with the resistor getting too hot. I could leave the wire disconnected all the time and the radio works ok. According to the wiring diagram it is supposed to have that wire connected. Something is causing it to draw excessive current but not all the time. All the tubes tested good, and I even swapped them out so I know that the tubes are not the problem. Please help Thanks in advance. This is my first post so please forgive me If I did something wrong.
Philco 60 hot resistor - by knox - 02-17-2022, 04:07 PM
RE: Philco 60 hot resistor - by mikethedruid - 02-17-2022, 06:33 PM
RE: Philco 60 hot resistor - by klondike98 - 02-17-2022, 09:17 PM
RE: Philco 60 hot resistor - by Lewiss - 02-21-2022, 02:44 PM
Thanks, everyone! I suppose I’ll keep these installed since I have them and they do fit. But moving forward I’ll know th...jrblasde — 07:57 AM
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
There are currently 3579 online users. [Complete List]
» 3 Member(s) | 3576 Guest(s)
