Advice needed on hot air rework station
I worked with an AOYUE for over 6 years and it seemed to have had everything we needed. Has a lot of accessories. Nowadays they even have a vacuum pump for quickly removing solder. I think you can get a good one for $150-$200.
RE: Advice needed on hot air rework station - by RodB - 02-18-2022, 11:01 AM
