Kadette model 35 open iF
If both windings are good on the replacement ift you shouldn't have a problem retuning it to 448kc. That should solve the IF problem so far.
Even at 455kc could be lowered to 448 by adding some capacitance across each winding.
Kadette model 35 open iF - by NostalgiaRadioTime - 02-19-2022, 11:36 PM
RE: Kadette model 35 open iF - by Radioroslyn - 02-20-2022, 09:52 AM
RE: Kadette model 35 open iF - by Radioroslyn - 02-20-2022, 04:33 PM
RE: Kadette model 35 open iF - by RodB - 02-20-2022, 04:53 PM
RE: Kadette model 35 open iF - by Ron Ramirez - 02-20-2022, 08:00 PM
RE: Kadette model 35 open iF - by mikethedruid - 02-21-2022, 01:19 AM
RE: Kadette model 35 open iF - by RodB - 02-21-2022, 10:32 AM
RE: Kadette model 35 open iF - by Paul Philco322 - 02-25-2022, 09:14 PM
RE: Kadette model 35 open iF - by klondike98 - 02-26-2022, 02:30 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 8261 online users. [Complete List]
» 3 Member(s) | 8258 Guest(s)
