Kadette model 35 open iF
Those 1930s-1940s IF transformers usually had a fairly wide range of tuning, so you will likely be able to tune transformers designed for a 455 kc IF down to 448 kc without issue.
Kadette model 35 open iF - by NostalgiaRadioTime - 02-19-2022, 11:36 PM
RE: Kadette model 35 open iF - by Radioroslyn - 02-20-2022, 09:52 AM
RE: Kadette model 35 open iF - by Radioroslyn - 02-20-2022, 04:33 PM
RE: Kadette model 35 open iF - by RodB - 02-20-2022, 04:53 PM
RE: Kadette model 35 open iF - by Ron Ramirez - 02-20-2022, 08:00 PM
RE: Kadette model 35 open iF - by mikethedruid - 02-21-2022, 01:19 AM
RE: Kadette model 35 open iF - by RodB - 02-21-2022, 10:32 AM
RE: Kadette model 35 open iF - by Paul Philco322 - 02-25-2022, 09:14 PM
RE: Kadette model 35 open iF - by klondike98 - 02-26-2022, 02:30 PM
