Philco 60 hot resistor
Hi,
Be sure you are using the proper schematic, check here to find out what run your Model 60 is, and then reference the proper schematic.
https://philcoradio.com/library/index.ph...-model-60/
I just completed a Run 7 Model 60, it can be very confusing until you identify which Model 60 you have.
Philco 60 hot resistor - by knox - 02-17-2022, 04:07 PM
RE: Philco 60 hot resistor - by mikethedruid - 02-17-2022, 06:33 PM
RE: Philco 60 hot resistor - by klondike98 - 02-17-2022, 09:17 PM
RE: Philco 60 hot resistor - by Lewiss - 02-21-2022, 02:44 PM
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
