Dry Cleaning grill cloth
I have tried soaking old cloth in a mixture of Woolite and water, with mixed results. Most turned out ok but some fell apart in the Woolite bath.
I doubt that the dry cleaners could do anything with the cloth while still attached to the board, but I could be wrong...
Dry Cleaning grill cloth - by madsowry - 02-23-2022, 11:30 PM
RE: Dry Cleaning grill cloth - by Ron Ramirez - 02-24-2022, 12:22 AM
RE: Dry Cleaning grill cloth - by madsowry - 02-24-2022, 12:42 AM
RE: Dry Cleaning grill cloth - by falcon123 - 04-30-2022, 06:44 AM
RE: Dry Cleaning grill cloth - by klondike98 - 04-30-2022, 03:16 PM
