Philco 16B inter-station noise suppression question
w4rtc Wrote:Hi
Have you tried Nostalgia Air? They have a schematic it is hard to read in some places but is all I have. Yes there is supposed to be a toggle switch to turn the feature on and off, one of the wires should connect to the cathode of the Q.A.V.C 78 tube and the other wire goes to ground. If that is where the wires go yes you can tie them togather to turn on the feature, then the feature should work and the control on the back will set the threshold for the stations to come thru. Hope this helps Joe
Where was the toggle switch attached . I don't see any hole (filled or otherwise) in the cathedral cabinet (It has been refinished) or obvious place on the chassis where a toggle switch may have resided.
Mark
The speaker table error?
Philco 70 antenna lead
