Philco 60
OK, first connect up the signal generator to put out just an AUDIO signal, cable connected to the AUDIO OUT Jack. Turn it on. put a .1 MFD cap on the center lead of the cable, and ground the braid to the radio chassis. touch the other end of the cap to the plate terminal of the #75 tube socket (pin 2). With the radio on and warm, this should inject an audio signal into the circuit at that point. This will let you check the #42 tube and audio output circuits. You should hear the audio tone from the signal generator.
Next touch this end of the cap to the cap of the #75 tube. Again you should hear the tone.
Now switch the probe connection to the RF out. Set the sig gen to 460KC with AF modulation. Change the cap on the output of the probe to a .001 MFD. Leave the shield connected to chassis.
Connect the other end of the .001 cap to the plate terminal of the #78 tube (pin 2). You should hear the tone. Adjust cap #26 until tone is at its loudest. This sets the 2nd IF transformer.
Next switch the capacitor connection to the plate of the 6A7 tube (pin 2). Adjust capacitors #18 and #16 for the loudest tone output. This should align your IF.
I find the Rider's information actually better for aligning these receivers, so here is a link to those pages on Nostalgia Air. This is a pretty good scan, and you should find the information it gives on alignment useful, so read all the pages.
http://www.nostalgiaair.org/PagesByModel...013793.pdf
Philco 60 - by Ralph - 12-29-2021, 11:34 AM
RE: Philco 60 - by Radioroslyn - 12-29-2021, 12:56 PM
RE: Philco 60 - by Ralph - 12-29-2021, 07:29 PM
RE: Philco 60 - by Radioroslyn - 12-29-2021, 08:43 PM
RE: Philco 60 - by Ralph - 01-31-2022, 08:13 AM
RE: Philco 60 - by Radioroslyn - 01-31-2022, 09:22 AM
RE: Philco 60 - by Ralph - 01-31-2022, 04:19 PM
RE: Philco 60 - by Radioroslyn - 01-31-2022, 04:58 PM
RE: Philco 60 - by sk373a@gmail.com - 02-01-2022, 10:06 AM
RE: Philco 60 - by Lewiss - 02-02-2022, 02:21 PM
RE: Philco 60 - by Ralph - 02-03-2022, 11:10 AM
RE: Philco 60 - by Lewiss - 02-03-2022, 06:22 PM
RE: Philco 60 - by Ralph - 02-04-2022, 04:40 PM
RE: Philco 60 - by Radioroslyn - 02-04-2022, 05:27 PM
RE: Philco 60 - by Ralph - 02-04-2022, 05:59 PM
RE: Philco 60 - by Ralph - 02-18-2022, 07:40 PM
RE: Philco 60 - by Lewiss - 02-21-2022, 02:37 PM
RE: Philco 60 - by mikethedruid - 02-21-2022, 07:22 PM
RE: Philco 60 - by Ralph - 02-24-2022, 05:12 PM
RE: Philco 60 - by mikethedruid - 02-24-2022, 10:25 PM
RE: Philco 60 - by Mondial - 02-25-2022, 04:07 PM
RE: Philco 60 - by Ralph - 02-25-2022, 06:48 PM
RE: Philco 60 - by Ralph - 03-12-2022, 01:07 PM
RE: Philco 60 - by klondike98 - 03-12-2022, 01:16 PM
RE: Philco 60 - by Ralph - 03-12-2022, 01:26 PM
RE: Philco 60 - by klondike98 - 03-12-2022, 05:47 PM
Users browsing this thread: 18 Guest(s)
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
Ron yes, that was found. The problem is trying to find GE-10 for AR107/108. I could not find even mentioning of it. ...morzh — 09:06 AM
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM
Mike; Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
There are currently 3295 online users. [Complete List]
» 4 Member(s) | 3291 Guest(s)
AvatarAvatarAvatarAvatar
