Philco 60
Ralph, If you are hearing the IF signal when you connect your signal generator to the cap of the 78 tube but not when connected to the cap of the 6A7, there must be a problem between those stages. You should hear a loud 460 kc IF signal when connected to the 6A7 grid cap.
I would first check the IF transformer between the 6A7 plate and 78 grid for continuity. Both the primary and secondary windings should read less than 100 ohms. If the primary is open, you will have no plate voltage on the 6A7 and therefore hear no signal. Check the voltages on the 6A7 tube pins and compare to the typical readings given in the service info.
Don't worry about replacing mica caps until you have checked the other possibilities. Micas are pretty reliable and rarely need replacement.
Philco 60 - by Ralph - 12-29-2021, 11:34 AM
RE: Philco 60 - by Radioroslyn - 12-29-2021, 12:56 PM
RE: Philco 60 - by Ralph - 12-29-2021, 07:29 PM
RE: Philco 60 - by Radioroslyn - 12-29-2021, 08:43 PM
RE: Philco 60 - by Ralph - 01-31-2022, 08:13 AM
RE: Philco 60 - by Radioroslyn - 01-31-2022, 09:22 AM
RE: Philco 60 - by Ralph - 01-31-2022, 04:19 PM
RE: Philco 60 - by Radioroslyn - 01-31-2022, 04:58 PM
RE: Philco 60 - by sk373a@gmail.com - 02-01-2022, 10:06 AM
RE: Philco 60 - by Lewiss - 02-02-2022, 02:21 PM
RE: Philco 60 - by Ralph - 02-03-2022, 11:10 AM
RE: Philco 60 - by Lewiss - 02-03-2022, 06:22 PM
RE: Philco 60 - by Ralph - 02-04-2022, 04:40 PM
RE: Philco 60 - by Radioroslyn - 02-04-2022, 05:27 PM
RE: Philco 60 - by Ralph - 02-04-2022, 05:59 PM
RE: Philco 60 - by Ralph - 02-18-2022, 07:40 PM
RE: Philco 60 - by Lewiss - 02-21-2022, 02:37 PM
RE: Philco 60 - by mikethedruid - 02-21-2022, 07:22 PM
RE: Philco 60 - by Ralph - 02-24-2022, 05:12 PM
RE: Philco 60 - by mikethedruid - 02-24-2022, 10:25 PM
RE: Philco 60 - by Mondial - 02-25-2022, 04:07 PM
RE: Philco 60 - by Ralph - 02-25-2022, 06:48 PM
RE: Philco 60 - by Ralph - 03-12-2022, 01:07 PM
RE: Philco 60 - by klondike98 - 03-12-2022, 01:16 PM
RE: Philco 60 - by Ralph - 03-12-2022, 01:26 PM
RE: Philco 60 - by klondike98 - 03-12-2022, 05:47 PM
Users browsing this thread: 18 Guest(s)
Hi Richard. Yes, we are waiting for warm weather. I have more than a dozen hulls waiting to be painted.RadioSvit — 11:06 AM
Then it is even easier. Yep, my GE guide also says "Silicon".morzh — 09:43 AM
Mike, according to my ECG replacement guide, the AR107 & AR108 both cross reference to a ECG 123A as does a GE-10. T...462ron — 09:41 AM
The 66 Ohm filter in the 1st detector's plate circuit. Look in the early version sch. Here it is, the spiral that ma...morzh — 09:11 AM
Ron yes, that was found. The problem is trying to find GE-10 for AR107/108. I could not find even mentioning of it. ...morzh — 09:06 AM
Your output transistor X6 cross references to a GE-3 transistor and I’ve used that before. There are a few here on eBay…...462ron — 07:58 AM
Mike; Where was this RF choke located? I remember seeing on a few sets that had detector-amplifiers ahead of the powe...Arran — 02:29 AM
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
There are currently 3281 online users. [Complete List]
» 4 Member(s) | 3277 Guest(s)
AvatarAvatarAvatarAvatar
