Audio Output transformer info needed
I wasn't able to locate the schematic for a 46-431 to get the audio output power. Your schematic might have the spec. So let's say it's about 5 watts. You can get a 5 watt universal OPT for a very reasonable price. Make sure the primary impedance matches the 6K6 at around 7.6k ohms (6k - 8k) and the secondary matches to the speaker voice coil impedance, probably 3-4 ohms. You may get lucky and find one that has the same mounting holes. There's a way to calculate your unknown OPT impedance but you may not have the equipment.
RE: Audio Output transformer info needed - by RodB - 02-26-2022, 03:44 PM
This is the replacement guide for transistors by GE parts. So, GE-3 is your power replacement for AR14 Just ...morzh — 04:57 PM
Philco 91 Restore Code ??
How do I know if AVC is OK? For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I ...dconant — 04:46 PM
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output....y...morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM
If it does not get narrower with strong signal and your AVC is OK, it could veru well be that the shadowgraph's magnet i...morzh — 02:58 PM
The width does not get narrower with generator. I think I will try some other cap values.dconant — 02:56 PM
410pF is a large capacitance to parallel to a compensator. As for the shadowmeter....yes, 3/8" is a bit wide, bu...morzh — 02:49 PM
My new nostalgic video... My weekly video on radio history Who is interested - come, watch, critically evaluate the qu...RadioSvit — 01:47 PM
There are currently 3883 online users. [Complete List]
» 3 Member(s) | 3880 Guest(s)
