Philco 16B inter-station noise suppression question
Hi
The switch is 9 inches from bottom of cabinet and 1 inch from back of cabinet. Here is a picture of the switch.
[Image: http://i927.photobucket.com/albums/ad118...switch.jpg]
Hopes this helps.
Joe
The speaker table error?
Philco 70 antenna lead
