Joe's Maggie
Hi All Steve what gloss should I use for the first two coats of lacquer before the toner is put on? I did buy a quart of Behlen grain filler. Also did buy some golden oak toner. How do you spread the filler (cloth scraper etc.) what do you wipe it (cross grain) with (burlap?) I am guessing the finish lacquer should satin on semi-gloss I dont want it to look to shiney. I saw the cabinet work you did for Ron, you really do good work
Thanks Joe
Joe's Maggie - by w4rtc - 03-27-2011, 12:14 AM
RE: Joe's Maggie - by ipwizard - 03-02-2012, 05:16 PM
Re: Joe's Maggie - by Doug Houston - 03-27-2011, 08:38 PM
Re: Joe's Maggie - by w4rtc - 03-30-2011, 11:59 AM
Re: Joe's Maggie - by codefox1 - 03-30-2011, 01:47 PM
Re: Joe's Maggie - by Ron Ramirez - 03-31-2011, 07:44 PM
Re: Joe's Maggie - by Steve Davis - 03-31-2011, 09:14 PM
Re: Joe's Maggie - by w4rtc - 04-07-2011, 02:31 PM
Re: Joe's Maggie - by w4rtc - 04-12-2011, 12:54 PM
Re: Joe's Maggie - by Ron Ramirez - 04-12-2011, 01:10 PM
Re: Joe's Maggie - by Doug Houston - 04-12-2011, 11:35 PM
Re: Joe's Maggie - by Arran - 04-13-2011, 08:29 PM
Re: Joe's Maggie - by w4rtc - 05-08-2011, 01:37 PM
Re: Joe's Maggie - by codefox1 - 05-08-2011, 03:59 PM
Re: Joe's Maggie - by Steve Davis - 05-08-2011, 05:04 PM
Re: Joe's Maggie - by w4rtc - 05-08-2011, 05:07 PM
Re: Joe's Maggie - by w4rtc - 05-08-2011, 05:12 PM
Re: Joe's Maggie - by w4rtc - 05-09-2011, 04:01 PM
Re: Joe's Maggie - by w4rtc - 05-11-2011, 08:03 PM
Re: Joe's Maggie - by Ron Ramirez - 05-11-2011, 08:13 PM
Re: Joe's Maggie - by w4rtc - 09-26-2011, 08:34 PM
Re: Joe's Maggie - by Ron Ramirez - 09-26-2011, 09:01 PM
Re: Joe's Maggie - by w4rtc - 02-15-2012, 11:49 PM
Re: Joe's Maggie - by codefox1 - 02-16-2012, 10:09 AM
Re: Joe's Maggie - by Ron Ramirez - 02-16-2012, 05:20 PM
There are currently 10347 online users. [Complete List]
» 2 Member(s) | 10345 Guest(s)
