Two new additions
Now, let Chuck Schwark know what city the dial scale is on the '38 set. He was he was gathering data on how many dial scales were made for those Cone--Centric tuned Philcos.
Two new additions - by 37silverstreak - 05-07-2011, 03:52 PM
Re: Two new additions - by Ron Ramirez - 05-07-2011, 08:16 PM
Re: Two new additions - by exray - 05-07-2011, 08:17 PM
Re: Two new additions - by TA Forbes - 05-07-2011, 10:04 PM
Re: Two new additions - by gary rabbitt - 05-08-2011, 01:35 AM
Re: Two new additions - by Doug Houston - 05-08-2011, 03:06 PM
Re: Two new additions - by 37silverstreak - 05-08-2011, 03:58 PM
Re: Two new additions - by w4rtc - 05-08-2011, 11:33 PM
Philco 91 Tuning Condenser
