Halson model 610 electrolytics
According to the schematic, the white and black go to ground, the green goes to the junction of 11 & 12 voltage divider, one red goes to the end of the voltage divider at 11 and the other red goes to pin one or four of the 80 tube.
RE: Halson model 610 electrolytics - by Mondial - 03-04-2022, 01:31 AM
RE: Halson model 610 electrolytics - by RodB - 03-04-2022, 11:21 AM
RE: Halson model 610 electrolytics - by Mondial - 03-04-2022, 12:44 PM
RE: Halson model 610 electrolytics - by RodB - 03-04-2022, 04:30 PM
RE: Halson model 610 electrolytics - by morzh - 03-04-2022, 08:31 PM
RE: Halson model 610 electrolytics - by morzh - 03-04-2022, 08:44 PM
RE: Halson model 610 electrolytics - by morzh - 03-04-2022, 10:46 PM
