Halson model 610 electrolytics
Sounds like Mondial is going in the right direction. If that fixes the hum be sure to check the bias voltages.
RE: Halson model 610 electrolytics - by Mondial - 03-04-2022, 01:31 AM
RE: Halson model 610 electrolytics - by RodB - 03-04-2022, 11:21 AM
RE: Halson model 610 electrolytics - by Mondial - 03-04-2022, 12:44 PM
RE: Halson model 610 electrolytics - by RodB - 03-04-2022, 04:30 PM
RE: Halson model 610 electrolytics - by morzh - 03-04-2022, 08:31 PM
RE: Halson model 610 electrolytics - by morzh - 03-04-2022, 08:44 PM
RE: Halson model 610 electrolytics - by morzh - 03-04-2022, 10:46 PM
There are currently 9073 online users. [Complete List]
» 1 Member(s) | 9072 Guest(s)
