my newly cleaned up 37-650
The grill cloth is readily available as a reproduction from several sources, the knobs can be found either as reproductions or as originals, they were in common use from about 1936-1940 on multiple models in either black or brown Bakelite.
my newly cleaned up 37-650 - by scottericsonon - 05-07-2011, 04:06 PM
Re: my newly cleaned up 37-650 - by Uffda - 05-07-2011, 04:37 PM
Re: my newly cleaned up 37-650 - by Ron Ramirez - 05-07-2011, 08:14 PM
Re: my newly cleaned up 37-650 - by Uffda - 05-07-2011, 08:59 PM
Re: my newly cleaned up 37-650 - by Ron Ramirez - 05-07-2011, 09:49 PM
Re: my newly cleaned up 37-650 - by TA Forbes - 05-07-2011, 10:02 PM
Re: my newly cleaned up 37-650 - by Uffda - 05-07-2011, 10:55 PM
Re: my newly cleaned up 37-650 - by gary rabbitt - 05-08-2011, 01:34 AM
Re: my newly cleaned up 37-650 - by Doug Houston - 05-08-2011, 11:37 PM
Re: my newly cleaned up 37-650 - by TA Forbes - 05-09-2011, 12:16 AM
Re: my newly cleaned up 37-650 - by Arran - 05-09-2011, 01:27 AM
Re: my newly cleaned up 37-650 - by Doug Houston - 05-10-2011, 06:03 PM
Re: my newly cleaned up 37-650 - by TA Forbes - 05-10-2011, 10:01 PM
Eico 232 VTVM Schematic
There are currently 8794 online users. [Complete List]
» 2 Member(s) | 8792 Guest(s)
