Philco 37-670 problem finally solved
Before you toss that 6K7, try resoldering the pins on the base as well as the grid cap, particularly the cathode pin, I found a 6K6 tube like that lately, tube lit up but no reading.
Re: Philco 37-670 problem finally solved - by Arran - 05-09-2011, 01:42 AM
The speaker table error?
Philco 70 antenna lead
There are currently 6116 online users. [Complete List]
» 1 Member(s) | 6115 Guest(s)
