Enameled Wire?
I doubt it is enameled wire going to a speaker, unless it routs far away from the chassis, or anything it might short against. With just a little rubbing from vibration enamel insulation can fail. More likely it had rubber insulation which has rotted away and disappeared.
Enameled Wire? - by Paul Philco322 - 03-26-2022, 08:10 PM
RE: Enameled Wire? - by morzh - 03-26-2022, 09:10 PM
RE: Enameled Wire? - by mikethedruid - 03-27-2022, 12:24 AM
RE: Enameled Wire? - by Paul Philco322 - 03-27-2022, 08:26 AM
RE: Enameled Wire? - by Ron Ramirez - 03-27-2022, 09:30 AM
RE: Enameled Wire? - by Mondial - 03-27-2022, 11:41 AM
RE: Enameled Wire? - by mikethedruid - 03-27-2022, 02:50 PM
RE: Enameled Wire? - by Ron Ramirez - 03-27-2022, 03:06 PM
RE: Enameled Wire? - by Paul Philco322 - 03-27-2022, 07:41 PM
RE: Enameled Wire? - by Ron Ramirez - 03-27-2022, 07:53 PM
RE: Enameled Wire? - by Paul Philco322 - 03-27-2022, 08:02 PM
RE: Enameled Wire? - by Paul Philco322 - 04-01-2022, 07:59 PM
