Enameled Wire?
Yes, I agree with Ron. Many times there are no separate insulated leads from the output transformer secondary winding. The actual enameled magnet wire of the secondary extends out from the transformer and connects directly to the speaker voice coil. If there is any real concern of shorting, a piece of insulating tubing can be slipped over the wire in question.
Enameled Wire? - by Paul Philco322 - 03-26-2022, 08:10 PM
RE: Enameled Wire? - by morzh - 03-26-2022, 09:10 PM
RE: Enameled Wire? - by mikethedruid - 03-27-2022, 12:24 AM
RE: Enameled Wire? - by Paul Philco322 - 03-27-2022, 08:26 AM
RE: Enameled Wire? - by Ron Ramirez - 03-27-2022, 09:30 AM
RE: Enameled Wire? - by Mondial - 03-27-2022, 11:41 AM
RE: Enameled Wire? - by mikethedruid - 03-27-2022, 02:50 PM
RE: Enameled Wire? - by Ron Ramirez - 03-27-2022, 03:06 PM
RE: Enameled Wire? - by Paul Philco322 - 03-27-2022, 07:41 PM
RE: Enameled Wire? - by Ron Ramirez - 03-27-2022, 07:53 PM
RE: Enameled Wire? - by Paul Philco322 - 03-27-2022, 08:02 PM
RE: Enameled Wire? - by Paul Philco322 - 04-01-2022, 07:59 PM
