Philco 51 mantel clock & radio
The early synchronous clocks that are not self starting all have a slight noisy growl when they are running. This is normal. It should sound a little bit like a kitten purring. Don't be worried unless its considerably noiser than a kitten.
Philco 51 mantel clock & radio - by Guest - 04-04-2006, 10:35 PM
[No subject] - by Chuck Schwark - 04-04-2006, 10:51 PM
[No subject] - by PTurney - 04-04-2006, 11:01 PM
[No subject] - by Chuck Schwark - 04-04-2006, 11:25 PM
[No subject] - by Guest - 04-05-2006, 08:46 AM
[No subject] - by PTurney - 04-05-2006, 03:18 PM
[No subject] - by Guest - 04-05-2006, 04:31 PM
Model 551 Colonial Clock - by Guest - 04-21-2006, 09:30 AM
[No subject] - by PTurney - 04-25-2006, 08:53 AM
[No subject] - by Guest - 04-25-2006, 07:13 PM
