Restoring Philco model 87
Wendell,
As I mentioned in my pm I just p/u a model 87.
Being the daredevil that I am I plugged her in
and gave her juice. Everything seems OK but
voltage are way down so it going to get the
filter bank rebuilt. Started in on that but noticed
it takes a lot of heat to get the solder joints
apart. If you cut the wires they'll be too short
to resolder. Just thought I'd mention it to you,
I'll need a least a 60W iron. That will just about
do the job with saying too much bad words.
100W job would be even better. Forget a little
30W shady o rack.
Restoring Philco model 87 - by wendell - 06-24-2011, 09:35 PM
Re: Restoring Philco model 87 - by 7estatdef - 06-24-2011, 11:28 PM
Re: Restoring Philco model 87 - by wendell - 06-24-2011, 11:46 PM
Re: Restoring Philco model 87 - by 7estatdef - 06-25-2011, 07:21 AM
Another question about a model 87 - by wendell - 06-25-2011, 07:57 PM
Re: Restoring Philco model 87 - by 7estatdef - 06-25-2011, 10:53 PM
Re: Restoring Philco model 87 - by Arran - 06-29-2011, 08:25 PM
Re: Restoring Philco model 87 - by wendell - 06-29-2011, 09:14 PM
Re: Restoring Philco model 87 - by 7estatdef - 06-29-2011, 09:54 PM
Re: Restoring Philco model 87 - by Ron Ramirez - 06-30-2011, 08:06 AM
Re: Restoring Philco model 87 - by wendell - 06-30-2011, 09:57 AM
Re: Restoring Philco model 87 - by Ron Ramirez - 06-30-2011, 03:50 PM
Re: Restoring Philco model 87 - by Arran - 06-30-2011, 06:49 PM
Re: Restoring Philco model 87 - by Texasrocker - 07-01-2011, 09:22 PM
Re: Restoring Philco model 87 - by codefox1 - 07-01-2011, 11:09 PM
Re: Restoring Philco model 87 - by wendell - 07-08-2011, 10:37 AM
Re: Restoring Philco model 87 - by wendell - 07-08-2011, 10:48 AM
Re: Restoring Philco model 87 - by Ron Ramirez - 07-08-2011, 11:15 AM
Re: Restoring Philco model 87 - by wendell - 07-08-2011, 11:34 AM
Re: Restoring Philco model 87 - by 7estatdef - 07-11-2011, 03:06 PM
Re: Restoring Philco model 87 - by codefox1 - 07-11-2011, 03:41 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6070 online users. [Complete List]
» 1 Member(s) | 6069 Guest(s)
