1935 Philco model 45L
Hello, Keith: The 45L is a nice looking set. Congrats!
Check out the "Resources" listed here on the main (home) page. Here you will find different vendors who can supply you with all the items you might require.
I personally have used several of Mark Oppat's dial scales that he has on his Old Radio Parts[i] [/i] site and they are excellent. He is also the aptly named "King of Controls" and has a huge stock of different switches and pots available.
1935 Philco model 45L - by keith49vj3 - 05-09-2011, 08:00 PM
Re: 1935 Philco model 45L - by 7estatdef - 05-09-2011, 08:36 PM
Re: 1935 Philco model 45L - by keith49vj3 - 05-09-2011, 09:18 PM
Re: 1935 Philco model 45L - by TA Forbes - 05-09-2011, 10:20 PM
Re: 1935 Philco model 45L - by keith49vj3 - 05-29-2011, 03:24 PM
Re: 1935 Philco model 45L - by exray - 05-29-2011, 05:39 PM
Re: 1935 Philco model 45L - by keith49vj3 - 05-30-2011, 08:18 AM
The speaker table error?
Philco 70 antenna lead
