Lacquer and grain filler sources
Thanks for the responses. I looked at the cdmcabinethardware site. They showed two Mohawk propducts - the tone finish lacquer and the ultra classic toner. Is one of these the paint and the other the clear lacquer? How may coats of each do you apply and do you sand and polish with compound after the lacquer is sprayed? Thanks, Bob
Lacquer and grain filler sources - by rck46 - 05-07-2011, 09:09 PM
Re: Lacquer and grain filler sources - by cwysong - 05-08-2011, 07:01 PM
Re: Lacquer and grain filler sources - by exray - 05-08-2011, 07:32 PM
Re: Lacquer and grain filler sources - by rck46 - 05-09-2011, 10:37 PM
Re: Lacquer and grain filler sources - by cwysong - 05-10-2011, 08:50 PM
Re: Lacquer and grain filler sources - by exray - 05-10-2011, 09:14 PM
