Philco Predicta board lifted trace and trace corrosion.
hello Jas,
First all Do you have a solder sucker or solder wick I would try to remove some of that soler then clean the area and try soldering some new solder also what you are using to soler with? myself I would use my temperature soldering iron.
Too much heat will cause issues also not enough heat will also cause issues .
RE: Philco Predicta board lifted trace and trace corrosion. - by radiorich - 04-08-2022, 01:49 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9929 online users. [Complete List]
» 2 Member(s) | 9927 Guest(s)
