Philco 42-380 safety cap
Well you could always buy an old Eico 625, or if you want to upgrad, youi could buy a Hickok. Mine is a model 539.
Then again, your 41 tube ie electrically almost identical to the 6K6, so if you had an octal plug (as in salvaged from an octal tube dud, a six prong femail socket, and the pinouts (use nostalgia air on he web or any tube manual,) You could make an adapter. This would also work for measuring a 42 tube using 6F6 settings, and maybe others.
Philco 42-380 safety cap - by gennet2 - 06-14-2011, 08:53 PM
Re: Philco 42-380 safety cap - by Steve Davis - 06-14-2011, 10:17 PM
Re: Philco 42-380 safety cap - by gennet2 - 06-15-2011, 06:05 AM
Re: Philco 42-380 safety cap - by gennet2 - 06-15-2011, 06:17 AM
Re: Philco 42-380 safety cap - by exray - 06-15-2011, 05:34 PM
Re: Philco 42-380 safety cap - by gennet2 - 06-16-2011, 06:07 AM
Re: Philco 42-380 safety cap - by Ron Ramirez - 06-16-2011, 06:19 AM
Re: Philco 42-380 safety cap - by exray - 06-16-2011, 09:51 AM
Re: Philco 42-380 safety cap - by gennet2 - 06-16-2011, 03:09 PM
Re: Philco 42-380 safety cap - by codefox1 - 06-16-2011, 04:04 PM
Re: Philco 42-380 safety cap - by gennet2 - 06-17-2011, 06:06 AM
Re: Philco 42-380 safety cap - by Steve Davis - 06-17-2011, 06:30 PM
Re: Philco 42-380 safety cap - by exray - 06-17-2011, 07:10 PM
Re: Philco 42-380 safety cap - by Steve Davis - 06-17-2011, 07:28 PM
Re: Philco 42-380 safety cap - by Marsupial - 06-17-2011, 08:18 PM
Re: Philco 42-380 safety cap - by codefox1 - 06-17-2011, 10:25 PM
Re: Philco 42-380 safety cap - by gennet2 - 06-18-2011, 03:36 PM
Re: Philco 42-380 safety cap - by codefox1 - 06-18-2011, 11:54 PM
Re: Philco 42-380 safety cap - by Marsupial - 06-19-2011, 07:53 AM
Re: Philco 42-380 safety cap - by Arran - 06-20-2011, 06:12 PM
Re: Philco 42-380 safety cap - by Marsupial - 06-21-2011, 08:58 AM
Philco 91 Tuning Condenser
There are currently 9815 online users. [Complete List]
» 1 Member(s) | 9814 Guest(s)
