Johnson Viking ll
They own a screw factory. Across the back, the bottom cover, and there's 6 or 8 on the inside of the front panel connecting it to the sides.
Johnson Viking ll - by vecher - 04-10-2022, 01:58 PM
RE: Johnson Viking ll - by Radioroslyn - 04-10-2022, 02:23 PM
RE: Johnson Viking ll - by vecher - 04-11-2022, 12:03 AM
RE: Johnson Viking ll - by Radioroslyn - 04-11-2022, 12:29 PM
