my newly cleaned up 37-650
Well, OK. Just notice that the bezel on the 38-2670 is the same size as the 37-650's that I have. The 38-2670 IS A 5 BAND SET.
One thing that I wonder about now, is hat the INNER bezels differ quite a bit. I was measuring the OUTER bezels. It would be true that the opening for the dial scale had to be bigger than on the 3 or 4 ban models.
my newly cleaned up 37-650 - by scottericsonon - 05-07-2011, 04:06 PM
Re: my newly cleaned up 37-650 - by Uffda - 05-07-2011, 04:37 PM
Re: my newly cleaned up 37-650 - by Ron Ramirez - 05-07-2011, 08:14 PM
Re: my newly cleaned up 37-650 - by Uffda - 05-07-2011, 08:59 PM
Re: my newly cleaned up 37-650 - by Ron Ramirez - 05-07-2011, 09:49 PM
Re: my newly cleaned up 37-650 - by TA Forbes - 05-07-2011, 10:02 PM
Re: my newly cleaned up 37-650 - by Uffda - 05-07-2011, 10:55 PM
Re: my newly cleaned up 37-650 - by gary rabbitt - 05-08-2011, 01:34 AM
Re: my newly cleaned up 37-650 - by Doug Houston - 05-08-2011, 11:37 PM
Re: my newly cleaned up 37-650 - by TA Forbes - 05-09-2011, 12:16 AM
Re: my newly cleaned up 37-650 - by Arran - 05-09-2011, 01:27 AM
Re: my newly cleaned up 37-650 - by Doug Houston - 05-10-2011, 06:03 PM
Re: my newly cleaned up 37-650 - by TA Forbes - 05-10-2011, 10:01 PM
There are currently 4875 online users. [Complete List]
» 1 Member(s) | 4874 Guest(s)
