First attempt at rewinding an oscillator coil (Phil 38-12)
Sounds like it's working! Was the set working for a bit after you replaced the caps? Just to find out where your at, set the 38-12 dial at 550kc.Listen with a set with good calibration place the ant wire near the 6A7 tube it should be heard at 1020kc. If you here it higher in frequency you need to add some more turns. Lower remove a few.
Re: First attempt at rewinding an oscillator coil (Phil 38-1 - by 7estatdef - 05-10-2011, 07:31 PM
The speaker table error?
Philco 70 antenna lead
