"Restore-A-Finish" question.
Hey Scott,
Thanks for your reply. based on your photo's, I decided to go ahead and give "Restore-A-Finish" a try! That stuff is amazing!!
My recent find- a 38-4xx had an intact orirginal finish, just like your 37-650x. I couldn't believe how nice it turned out! I like to keep the original finish as well, if it can be made to look good again. I have several other set's I want to try this stuff on. Thanks again.
Kevin
"Restore-A-Finish" question. - by 37silverstreak - 05-08-2011, 11:18 AM
Re: "Restore-A-Finish" question. - by 37silverstreak - 05-10-2011, 07:34 PM
Re: "Restore-A-Finish" question. - by TA Forbes - 05-10-2011, 10:36 PM
Re: "Restore-A-Finish" question. - by dcastor - 08-10-2011, 01:49 PM
Re: "Restore-A-Finish" question. - by Marsupial - 08-13-2011, 11:56 PM
Re: "Restore-A-Finish" question. - by Dave - 08-14-2011, 09:01 PM
There are currently 10531 online users. [Complete List]
» 2 Member(s) | 10529 Guest(s)
