Philco 51-930 resistor and capacitor questions
Hello Terry,
So, I am guessing the 200k would making it brighter sounding far as the audio tone goes then the 100k ?
You Said in Series, right? So maybe I will add a terminal strip between the audio output trans and C12 so that I can tack in the resistor to see what one sounds the best .
P.S. worst thing about restoring this radio is replacing the bad tuner grommets .
RE: Philco 51-930 resistor and capacitor questions - by radiorich - 04-20-2022, 10:12 PM
There are currently 3782 online users. [Complete List]
» 2 Member(s) | 3780 Guest(s)
