Philco 91X
I must admit, even though I like the radio, I am really weighing my pros and cons this time around. I have found it hard to sell radios myself around my region, even when I've tried selling below what they cost me to buy and get repaired years back. With that and the fact that my budget is getting hit by what is supposed to be my new radio hauler, I'm being rather picky this time around.
Thanks for the advice.
Philco 91X - by Jayce - 05-10-2011, 07:55 PM
Re: Philco 91X - by TA Forbes - 05-10-2011, 10:31 PM
Re: Philco 91X - by Jayce - 05-10-2011, 11:52 PM
Re: Philco 91X - by Ron Ramirez - 05-11-2011, 07:37 AM
Re: Philco 91X - by Jayce - 05-11-2011, 01:32 PM
Re: Philco 91X - by Arran - 05-12-2011, 12:09 AM
Re: Philco 91X - by Jayce - 05-12-2011, 11:32 AM
