Shadow Meter Coil Resistance On 37-650
Thanks Terry, I've restored the chassis complete and I'm ready to reassemble all the parts, cap blocks restuffed, IF cans rewired and everything else that goes into a complete restoration. Just wanted to make sure this reading was in the ballpark before I proceeded. My first experience with a shadow meter. In fact I still don't know what it does or how it works. I know that something is adjustable on the coil section that moves a small piece inside the housing but that's about all I know at this time.
John
"It's Nice To Be Nice To The Nice"
Major Frank Burns Mash 4077th
Re: Shadow Meter Coil Resistance On 37-650 - by Pepperoni - 05-11-2011, 08:40 PM
The speaker table error?
Philco 70 antenna lead
